Not sure if this is the right place so move it if it isnt.
Anyway i have a b3 carby turbo. Im wanting to switch it to FI. I have purchased the following parts tht i think i need.
Intake with injectors and fuel rail
throttle body
vaf and ecu
complete car wiring harness out of a FI
And i have a FI tank with pump
If im missing something plz chime in.
Now my questions are whats the best way to do this? Should i pull the complete harness and install the other harness? Any other things i can do? Gussing it will be a PITA to swap harnesses. Also dont i just swap parts? Nothing more to it is there? Also my next question is what should i buy for a fmu? Or think the computer will adjust enough? Surley someone has swapped one to FI. Any tips an trick would be great. It can be done pretty easily i hope! Thanks guys!
throttle body
vaf and ecu
