I finished up the carb adapter to install a 1981 Escort 1.6L carb onto a 88-89 Festiva. I started with a generic weber install kit and expoxed and re drilled two of the stud holes on the upper plate (the Escort carb has a slightly longer flange). I originally was going to modify the lower plate as well, but the one I bought was not wide enuf. I purchased a piece of 3/8'' alum, drilled, tapped and generally removed everything that did not look like a carb adapter at school today. It all mounts and bolts together well. I wish I had better pics, but I assembled the piece at school and forgot to remove the allen head fastners.
