If jetted properly, can a Holley 6520 be used instead of a Weber 32/36 ?? If they can, Allstate Carburetors is having a sale on them, 11/24 thru 11/30. $52 + S&H.
Holley 6520 Carb a Weber Alternative ???
1988 Ford Festiva L w/5 speed & Weber 32/36 upgrade
1998 Isuzu Trooper 4X4
2005 Ford F-150 XLT Super Cab
1980 Kawasaki KZ1000 - B4 LTD w/Mikuni VM29s, Dyna S Ignition, Kerker 4-Into-1 Header & Vetter Fairing & Trunk
1981 Kawasaki KZ1000 - M CSR Stock w/Vetter Fairing
1981 Yamaha XJ550 - H Maxim -
I am willing to bet it will probably work
Electric choke.Last edited by bravekozak; 11-24-2012, 08:22 PM.
if you can jet it, it'll workTrees aren't kind to me...
I would stay away from that carb. There are too many unknowns. It's for a 2.2L engine so the jets are definately too big and would need replaced if available. The throttle butterfly shaft size is not known for sure unlike the 1.6L Escort which is known to be the same size as the Festiva carb. The choke shaft is parallel to the throttle shaft putting the choke assembly either to the front or the back and may cause clearance problems for the cable type throttle linkage you will need The carb appears to only have throttle linkage on one side which is on the opposite side from the fuel inlet. So one way or the other, either the throttle linkage will be wrong or the fuel inlet will be. This would just add to additional unnecessay changes which you wouldn't have with the Escort/Weber carb.You gonna race that thing?
Allstate Carbs has a sale on Reman'd Weber 32/36s for $175.........worth checking out !!
WEBER323.jpg1988 Ford Festiva L w/5 speed & Weber 32/36 upgrade
How suitable for an early B6 installation would this reman Weber be? I have future plans to get another carbed Festiva if the stock carb can be eliminated from the equation. I want one car with NO computer controls at all!
Yea or nay?
If "yea" what would need fabbed? I'm assuming the adapter plate and linkage, minimum, onto a B3 intake on an early B6.
The Holley 6520 looks like the one we put on the 88. Used it as it came, except for the electric solenoid, on an adaptor. The electric choke quit after a while so we converted it to a manual. It's getting 36 mpg with the 4 spd, now changing to a 5spd , will see if that helps any. The spark plug color looks decent.
That Weber would be ok except for possibly having to change the jets. Maybe I missed it in the description, but I didn't see any mention of what size engine the carb comes jetted for. For about 1/3 the money, I would go with the Escort carb. Ebay usually has them in either new or rebuilt condition and the Escort was a 1.6L engine so it is correctly jetted for the B6. They have worked perfectly for me with good idle, good throttle response, and good WOT. With the Weber or the Escort carb and the distributor from a carbed Festiva, you can eliminate the computer completely. All you need is a hot wire to the "+" side of the coil and your up and running with no computer.Originally posted by Safety Guy View PostHow suitable for an early B6 installation would this reman Weber be? I have future plans to get another carbed Festiva if the stock carb can be eliminated from the equation. I want one car with NO computer controls at all!
Yea or nay?
You can use an adapter to fit the B3 or B6, but I prefer to fill in 3 of the 4 old mounting holes and build up the corners of the mounting location with aluminum weld. Then resurface the carb mounting face of the intake and drill and tap holes for the Weber/Escort carb mounting. It's been a while since I did a B6, but I think the half circle cable linkage from the Festiva carb is a direct bolt on to the Escort. The cable mounting bracket may or may not be a direct bolt on to the B6 valve cover. I've carbed every B series engine with the Escort carb except the B3 and the DOHC's and some required some fabrication to the cable mounting bracket including drilling new holes in the valve cover.
If you use the Escort carb, the Escort air cleaner will fit and clear under the hood, but you will need to cut a short piece off the "snout" because it goes almost tight against the radiator support crossmember. You can probably get one of those by doing a WTB on the Escort forum. The air cleaner is HUGE. Here's a pic of it:
Festy46, thanks for the info!!
