Stock Transmission is going out...Can I upgrade?
  • Stock Transmission is going out...Can I upgrade?
    Well it seems my transmission is starting to fail me. Recently it starting kicking the stick shift out of 4th gear. Soon I'll need to replace it, but I was curious if there is an upgrade I could switch to while I'm at it? I'm all for getting what's the best if my stock components are going out.
    My car: 1992 L 5 speed.
    If there isn't really an upgrade can I at least look for an Aspire transmission that would possibly have less miles on it? Tracking down a good used transmission with low miles is my best bet so I'm just curious if there is an upgrade or another transmission that my engine will accept besides just another Festiva 5 speed.
    -Rafe-
    Things I have for sale.
    Random Festiva Parts
    Re: Stock Transmission is going out...Can I upgrade?
    Yeah, Aspire, Capri, Sephia... You just have to make new trans mounts for all 3.
      So only the stock Festiva 5 speed is a direct bolt on? I'm not one for fabricating mounts...I barely have more than a ratchet and crescent wrench set!
      -Rafe-
        Yeah, Festiva trans is the only 100% fit.
          My understanding is that Aspire mounts retained to go with an Aspire tranny will swap direct to a Festy. Haven't done it myself, mind you. Your top end is going to drop but acceleration will definitely improve as will speedo calibration if you're running taller tires.
            So you are saying if I have the tranny from an Aspire...as long as it has the tranny mount it should bolt on?
            -Rafe-
              There really is no reason to "upgrade" the trans with a stock engine. Plenty of them go for hundreds of thousands of miles.
              91GL BP/F3A with boost
                PRAFESTON: The Aspire has a differnt final drive ratio.Your gas mileage will suffer if you use it. Thats why I put Festy trannys in my Aspires. But they are hard to come across in good shape. You can swap your ring & pinion gear,but thats a whole nother story. But if you do find a good Spire tranny you will need the xmember & front/rear mounts (including the metal bracket ). I would purchase new rubber mounts because they are usually junk after all these years.And like Bert said your speedo is gonna be off slightly.
                  Sounds like sticking with the stock is the way to go. Now to locate a decent one for cheap!
                  -Rafe-
                    Best of luck to you! I'm on the hunt for a stock Festy transmission, m'self. Found out from my Mechanic just today.
                      Looks like I have a source on a few. We'll see how it goes.
                      -Rafe-
                        i have an aspire motor and trans in my 88. i used the stock cross member from the festiva and mount from the aspire, afaik. i did the swap a long time ago. but it all bolts together
                          For the record Razorwing has an automatic. Thats what shes looking for.
                          Jerry
                          Team Lightning
                          Owner of Team Lightning
                          93 L Lightning. BP
                            I'm sorry but I have to disagree with that. The Festy front bracket is a 3 hole (Aspire is 4 hole). Also the Aspire front bracket moves the Rubber mount towards the drivers side by @ 1". I could see you using the stock festy xmember & front mount bracket (if you redrilled the bracket). I have pictures of all this but never posted because I didnt really think anyone would care.I just finished moding my setup so that it drops & lowers the motor/tranny @ 1.5" (festy tranny in an Aspire).
                              Hook me up please!!!!!! My college student son needs one for his festy badly!
