I've recently purchased an all metal* CSF brand automatic transmission radiator for my manual transmission '91 Festiva L.  DJ recommended an automatic radiator to replace the stock one on my manual transmission car as the cooling capacity is greater...and they are all that seems available anyway.
I am wondering if I might be able to use the otherwise unused automatic transmission cooler portion of the radiator as an engine oil cooler and wonder if anyone has done this?(someone at the local wrecking yard thought the idea was good "theoretically" and warned me to make sure to use good quality high temp oil lines)
My idea is to use a donut adapter between the spin on filter and engine such as Permacool sells...I've seen other brands also...which has an in and out for running an oil line to add on filters and coolers, and just route the line to the automatic transmission in and out on the bottom of the radiator.(does it matter which is in and which out?)
My goal is to have my engine last as long as possible, and I know running cool is helpful.(I'd also like to add a header exhaust, mild performance cam, balanced injectors, etcetera; with my budget these could wait a long time, though I've now installed FestivaMotorSport lowering springs and KYBs, 13" rims and a STILKO oil filter-I'm currently a TP true believer and will try to mention here if I regret it later)
The car had seemed to run pretty cool already even though the cooling fan has never worked since I've owned it, a problem in the wiring or relay or thermostat since the fan works fine itself.(I plan to try to fix this, but haven't had to since I haven't done much driving where I'm sitting still for long until lately) Adding oil capacity seems feasibley to be an additional bonus to longevity.
The problem that got me interested in all of this is that I'd used some Alumaseal when a leak developed where the core meets the bottom tank, and now the radiator won't hardly drain but at a drip rate and the motor seems to run warmer and I also need to try to clean out the idle speed control bypass air thermostat since it has never worked either and I'm told these often get gunked up with crud from inside the coolant system and will work again once they are cleaned out.
I plan to have the motor backflushed(actually a higher tech sort of similar operation commercially available) before I install the new radiator, once I've tried to see what I can do for the idle speed control bypass air thermostat congestion, and the cooling fan.(my warrenty on the radiator is no good if my fan doesn't work)
I know once I have a new radiator and the fan and such up and running my cooling will likely be very adequate, but I also think I might like to tow some sort of small trailer,(and/or drive in Death Valley, etc.) and just hate to see that auto trans cooler sit around doing nothing if it could be included in the mix functionally.
My question is, if I do all the plumbing well, will this be a reliable and worthwhile modification?
*copper core-brass tanks...when I did a search here at FordFestivaDOTcom someone said only Festiva radiators with plastic tanks were available, but I have the all metal one sitting in my tool room that proves that wrong-from RadiatorBarnDOTcom for $114.15
