The original throttle body would be replaced with an adapter. A flat plate with a round tube stub in it. The carb would be mounted up by the radiater support sheet metal, at least for the B3. The B6 would have the carb under the hood somewhere.
A metal tube or rubber hose would go from the carb to the adapter. This tube could be heated with 110v heat tape for cold climate start ups. You'd have to spin the motor a little longer to get it to fire.
You'd be limited to a manual choke. I'd have to rig an indicator light to remind me to take the choke off.
