Hold up...the slider carbs might not work...the butterfly stays open via the cable, but the slide opens with an vacuum draw from an opening intake valve(?) A common plenum would not allow the slides to open at all. Nuts!
Comments?
Constant Vacuum slide carb operation
Yeah, it would work. You might have to divide the plenum with a wall between cylinders 2 and 3.
Comments?
