how many different places can we place a turbo with our festiva/aspire setups. ive thought about placing on where the factory airbox of an aspire going. right behind the passenger side headlamp. or the more interesting position of rear mount. that one sounds like fun, but it also sounds inviting for thievery. yesterday i noticed a huge hole under the intake manifold behind the engine. theres gotta be enough room there to house a turbo, and itd be difficult to spot the booster in your engine bay. super stealth. any opinions about this spot?
turbo positioning.
that hole under the intake fills quickly once you get the 4 2+" tubes nessisary for the turbo to work, let alone the turbo itself... and the oil filter (though that can be relocated), and the axle movement and rack.... i think you'd find that you'd run out of room before the turbo is even in there.Trees aren't kind to me...
I'm thinking a better place would be just under the exhaust manifold. Not only is there room, but you would also get far better cooling than under the intake. And of course rear turbo is also an option.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
A stealthy rear turbo? In the spare tire well maybe? IDK.Any difference that makes no difference is no difference.
loud and a chance of CO intrusion.... keep everything out of the cabin.Trees aren't kind to me...
You could easily pop out a drain plug and box it in from the top with a removable cover. I don't really understand why you'd do all that though. I still don't understand why anyone wants to do a rear turbo in the first place on these cars, but to each his own.Any difference that makes no difference is no difference.
