DAE B-Series Billet Steel Rods
I forget, what do stock rods weigh? and what do other performance rods weigh? any plans to make aluminum rods? I know they don't handle the HP levels that steel can, but for N/A builds or a mild turbo setup, I think that would be awesome...
these are now on my list of parts for my engine build...
Mike, AKA the sasquatch
I talked to Matt 2 days ago.... he mentioned these rods were comming. AND other HI-PO rotating parts comming soon (hint hint).
not sure what i'm allowed to reveal on the site before he posts so i'll let it go at that.Trees aren't kind to me...
I am getting very excited, and confused....what to build B6T, BP, B3hmmmmmmBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
Stock rods weigh 547g, MANLEY rods weigh 533g but come standard with ARP 8740 cap screws with ARP2000 as an expensive upgrade, mine use ARP2000 standard. I actully have aluminium rods too,the misconseption is their weaker than steel, this is false! In most applications aluminum has a distinced advantage. I use areo space grade billet plate aluminum which is what my B3 rod will be made of. The reason is steel blanks are not available in 5.3605 center/center, i can get them made with min. order of 40 blanks. I have aluminum blanks with the correct center/center and can make 4 at time.I sent 1 rod out for stess testing, we simulated 125,000 mile with only .0018 rod stetch! thats equal to a steel rod.PROPOGATE! AND FACILITATE!
Aluminum B3 rods. Ooooooo.
festevil3 ok ill help you out
 you have a b3t in the works, you have a sohc b6 rear turbo torque blaster(barbie), & you have a super fast b6t race/street car(festycul) so the only logical thing to do is build a bpt with ac car! there problem solved!
						Last edited by kumalaba; 05-04-2013, 07:49 PM.Never Hire a Boy to do a Man's Job!!
<Read with the voice of Gimli from Lord of the Rings> Agreed! And you shall have my beard!Originally posted by kumalaba View Postfestevil3 ok ill help you out
Matt amazing job too!!! For your aluminum rods, are you going with 6061 or 7071?88L - Awaiting bigger and better things
92L - Dead and needs love - was DD
91 - Shell with title
92GL - receiving B8 Swap and will be DD
I saw these rods in person last Sat. Wish it were in the budget. They are very pretty.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig
I haven't tangled with connecting rods for quite some time but I do suspect they are always able to come apart. I see no visible joint at the main bearings at all on your rods! Is this some sort of proprietary process where perfect fit, or mating of surfaces, entails directionally breaking a single piece casting? They look real sharp Matt and I hope they provide folks with good service and performance.
