Sneak Peak
Wow... thats purdy! :shock:Dan
bp?
if so, these are also on my list of parts for my engine build
Mike, AKA the sasquatch
HOLY Quench area Batman!!!
are those the 12:1 low tention ring pistons you mentioned?Trees aren't kind to me...
going by the sneak peak they look very promissing, can we have more details?Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
If these are what i think they are (98% sure), these pistons will not use piston squiters in order to lower crank case windage. instead, the oil scrapers will pull double duty and force the cylinder wall oil tward the underside of the piston, instead of it getting forced from a squiter nozzle.Trees aren't kind to me...
You obveiously remember our conversation,this bp will have blocked oil spuirters so the skirt releaf is not needed.These pistons will get forced pin oilers drilled in the pin bore to provide pressurized oil to the pin.The benefit of cooling the underside of the piston in o.e. applications will not be needed in this engine as controling combustion temps,and anti knock, will be adressed by other means but the advantage in reducing windage and directing more oil to the rod and main bearings are a must when 9,000 rpm and 3hp per cube.PROPOGATE! AND FACILITATE!
I actually saw this done by another fellow whos an engine builder on mturbro.net everyone was like WTBBQF? But the more and more i mulch it over it makes perfect sense.Originally posted by mattdickmeyer View PostYou obveiously remember our conversation,this bp will have blocked oil spuirters so the skirt releaf is not needed.These pistons will get forced pin oilers drilled in the pin bore to provide pressurized oil to the pin.The benefit of cooling the underside of the piston in o.e. applications will not be needed in this engine as controling combustion temps,and anti knock, will be adressed by other means but the advantage in reducing windage and directing more oil to the rod and main bearings are a must when 9,000 rpm and 3hp per cube.
