B3 Build
  • B3 Build
    In the works: Dickmeyer Automotive header, FPR, Stage 3 head, and ported intake. Pictures as things progress. For now, any recommendations on what to use to clean all my oily dirty greasy parts?
    Josh Z.
    Dawn Power Dissolver will solve all your dirt and oil problems :thumbup:
    WWZD
    Zulu Ministries
      An old portable dishwasher for parts and do the above over and over under the hood until clean.
        One more thing about Power Dissolver. Always shake well before use, there's an ingredient in it that tends to congeal in the bottom of the bottle when it sits for a while. Spray it on and let it soak for 20-30 minutes. You'll notice after a while that it will form a bit of a "skin" on top. At that point shrub it around with a brush and then rinse clean. Usually takes no more than 2 treatments...and that's for really stubborn grease. If it requires a second treament, let everything dry well before the second application. This will keep any residual water from diluting the second pass.
        Another tip: The bottles of PD are kinda small and the sprayer tends to really lay it on. I've found I can make a bottle go further if I shake it up well, pour some in a small container, and then paint it on with a paintbrush. Basically applying it like paint stripper. PD acts in much the same as way aircraft stripper except it only strips dirt, oil, and grease.
        Stock up! You're going to love this stuff
        WWZD
        Zulu Ministries
          Where do you buy it?
          Josh Z.
            WalMart used to stock it but my local store stopped carrying it, yours may still have it. Luckily my local grocery store just started stocking it. Try this link to find a local retailer near you that has it.
            The page you're looking for can't be found. Browse Dawn's products, cleaning tips, and helpful guides instead.
            WWZD
            Zulu Ministries
              Also, if you can't find PD, Dawn make a grill cleaner that is the same product just in a slightly different bottle. Lowes Home Improvement has it.
              WWZD
              Zulu Ministries
                I can't find the Dawn PD around here anymore. I'll have to check out the grill cleaner. I've also found that Simple Green does an excellent job on dirty and mildly greasy stuff....but don't use it straight out of the bottle. It has to be diluted with water in order to work properly.
                  I'm a fan of Purple Power!
                  -Rafe-
                  Things I have for sale.
                  Random Festiva Parts
                    I just used your everyday name brand engine cleaner in a spray can. let it sit for about 10 miins or so an hit it with a pressure washer. ( I rented mine for 3 hrs and it only cost me $27)
                      Lol, when I was a kid we used Carbon Tetrachloride. I used to bathe in the stuff.Hmmm......wonder if that's why my kids have 6 toes and webbed fingers.....
                        Looks like the local dollar store carries the Dawn Power Dissolver.
                        Josh Z.
                          word! I love DPD!! I also recommend a harbor freight ultrasonic cleaner if you have the 80$ to spare, you won't regret it!
                          2008 Kia Rio- new beater
                          1993 Festiva- Fiona, DD
                          1997 Aspire- Babyspire, DD
                          1994 Aspire - Project Kiazord
                          1994 Aspire- Crustyspire, RIP
                            I like Purple Power too. I got a gallon jug and a chemical sprayer. Mix 2:1 PP:Water. It stripped my engine down till the aluminum had that "dry" look. Amazed me.
                              This! A thousand times this! I have used my HF ultrasonic cleaner more times than I can count. Well worth the money imo.
