I dont mean to bomb our forum with external info, but this write up is amazing.
G series complete tear down, LSD + 5th gear upgrade, and rebuild write up
Yea that's a good reference, I used it when I did the mfactory install. What they don't tell you is how to hold the gears from spinning when you crank the shaft nuts down
I'm looking for an e series write up like that lol..2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Awesome find, very good write up, bookmarkedBarbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
leave the 5th gear shift fork rollpin out, and engage another gear & 5th at the same time - the shafts will lock together because the gears are different ratios and everything binds fast. No harm to the transmission, and super easy way to remove the shaft nutsOriginally posted by zoom zoom View PostYea that's a good reference, I used it when I did the mfactory install. What they don't tell you is how to hold the gears from spinning when you crank the shaft nuts down
I'm looking for an e series write up like that lol..1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
