Just a few questions before I hit the 'buy-it-now' button on a Suzuki Samurai Weber carb kit..
Having A/C in the car, do I need to keep the EGR hooked up/will the current EGR plate fit the weber?
The dizzy is the only vacuum I'll have to keep, right? Everything else can be plugged/done away with?
.. and finally.
5-speed MPG? I got 39.4 when I filled yesterday, 285.6mi (adjusted for 155/80-13 tires) on 7.248 gallons. Will I still get 38+ driven sanely, or will it be closer to the 35 range? Seems the only weber MPG data I can find is with a 4-speed, which doesn't help me too much.
Thank you!
-Joe
.. and finally.
Thank you!
-Joe
