Weber swap electric choke hookup?
  • Weber swap electric choke hookup?
    Where do I hook up the Weber 32/36's electric choke on my '88?
    Thanks!
    White '88, 280kmi, Weber 32/36 DGEV Carb with Rocketman Carb Adapter
    Find a wire that is at 12V only when the engine is running, and hook it to that.
      I thought it needed a temperature controlled circuit of some sort to turn it off too?
        Mine works fine going to the original spot on the alternator.
          Awesome! Thats easy =)
          I'm going to run it through a dash switch so I can turn it off in the summer... may save a few ounces of fuel.
            You don't want to turn it off; it will then run choked when warm. The 12V source gradually opens the choke as the motor is warming up, then keeps it open via its constant voltage. When you shut the car off and it cools down over a period of a couple of hours, the choke spring also cools down so it will be closed when you start it up again. Just hook it to a 12V source (when running) and forget about it.
              THAT is why the choke plates hang half open the way they do.. Thanks Tom, makes sense now!
