I finally tore down my spare aspire tranny, word was third gear "was out, it makes a bad grinding noise."
I gave the case and the input gearshaft to a Nissan buddy who is gonna use it as a core on his new tranny. I kept the diff and ¿primary? Gearset in hopes of one day either welding this diff up or installing a limited slip(read phantom grip?)
Anyway when I tore it apart what I think was fourth gear had some teeth sheared off like the fifth gear on this shaft. It almost seems like they touched but why would they do that?
Anyway, pics! I'll find the other thread where someone measured up a neon diff and take measurements from this one to see if its remotely possible to make a neon LSD work, supposedly they have a cheap and effective way to convert to LSD vs welding the spiders solid.
also, for any interested parties, I counted the teeth 3 times...
ASPIRE TRANSMISSIONS HAVE 19 TEETH ON THE PINION GEAR AND 69 ON THE DIFFERENTIAL RING GEAR
WHICH MAKES IT A 4.0588235.... FINAL DRIVE RATIO!!
