when should one decide that the valves need to be reshimmed.my motor runs good just a slight rough idle and wondered about valve adjustment thnx.
valve adjustment
Carby or EFI? Gotta give us the info about your car. And there is no shimming on these valvetrains BTW.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
its a carb.
ok 89 with weber swap b3 jasper engine.msd ignition
new
rocketman adapter
plugs
wires
dizzy rotor and button
fuel filter
electric fuel pump with regulator at 3psi
coil
all gaskets and seals except head gasket
used
msd setup but worked good on the car it came from
carb was used but good shapebut has been used a lot for offroading rock climber I have already cleaned it and set float levelLast edited by 1chrisapple; 09-06-2013, 01:14 PM.
From your question about valve shimming, I take it you don't have a Haynes manual. Strongly recommend you get one, it will answer lots of basic questions.
The carbys use a screw-and-locknut valve adjustment system. How to do it will be in the Haynes manual.Last edited by TominMO; 09-06-2013, 02:15 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I thought you couldn't put a carby intake on an EFI head? Am I mistaken?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I think you can.Originally posted by TominMO View PostI thought you couldn't put a carby intake on an EFI head? Am I mistaken?Contact me for information about Festiva Madness!
yes you can put a carb intake on a EFI head (they're the same casting, as well as the 1G 323).Trees aren't kind to me...
Good to know. He has my favorite combination then, a Weber with hydro lifters.Last edited by TominMO; 09-07-2013, 06:49 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Yep, there's your sign! You'll like a B6 better anyway. It's more funner.Originally posted by 1chrisapple View Postfigured out my new used jasper motor has 90,120,150,185 compression I think that's my rough idle lol sucks but think im going b6 this time
Lifters don't go bad that often, and I'm not sure they would cause a rough idle issue.Last edited by TominMO; 09-07-2013, 05:38 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
