is the passenger side mounting area for the B6 engine block removable?
the reason i ask is because i have seen some passenger mounts/alternator brackets that look quite ideal from a kia rio 2001-2003 (i also think that that they have the alternator bracket there as well) that i'm thinking could take the place of them.
the idea is similar to the already established "L-shaped" passenger mount mod utilized by a lot of the members here already, but instead of the passenger mount reaching down towards the B6 mount for the engine block, it is bolted onto the back of the engine (closest to the firewall) and then from there, goes around the corner of the block and looks like it will sit where the original mount/mounting area would be found on the B6.
if this has been discussed already, i'll have this thread deleted.
i'll endeavor to get some photos of the mounts ASAP.. just as a mental note, the Kia engine block i saw these on look very similar to the B6 from the Capri as well in dimensions too. will have to get the tape measure on this one i think.
just to update everyone quickly, i'm feeling a lot better about my swap now.
. thanks 1chrisapple.
