hey guys,
Doing a B6 swap (Ford Capri B6) and was thinking about the fuel pump.. the pump itself will physically screw onto the tank, but the wiring is different.
The Festiva Wiring is three wires (three wires on the one plug) for its stock carb pump and the Capri's pump has 5 wires for it's wiring (4 wires to one plug and a secondary single wire for the 2nd)
Since i haven't done the wiring yet, would it be easy to run the new pump and use the wiring in conjuction with the capri's loom or is it easier to stick with getting a new EFI tank for the Festiva and use the stock wiring?
