Originally posted by db2u
Performance questions!
Ok, cool, just was a bit concerned you were going to get in over your head on it. Seriously though, as far as go fast on an 88 carb model... not having a lot of heavy stuff in the back, and getting it in good tune is about the best you can do. I also own an 88lx and am contemplating taking a EFI b6 from a 323 and swapping the intakes and possibly going electric fuel pump if there is no mech fuel pump provisions on the EFI engine.Oldest Festiva on the forum (so far) 3/87 LX - 225k
89 Tracer 13" alloys and dome light. Pioneer stereo, all else is stock.
You need a high pressure pump for EFI in order to have enough pressure to atomize the spray. Fuel injection won't work with a mechanical pump.Last edited by bravekozak; 11-28-2013, 06:53 PM.
The first gen B6 8 Valve SOHC has the block off plate for the mech fuel pump, The B6 that came in the later 80's 323 and Tracers, pump should be a bolt on affair.Originally posted by db2u View PostOk, cool, just was a bit concerned you were going to get in over your head on it. Seriously though, as far as go fast on an 88 carb model... not having a lot of heavy stuff in the back, and getting it in good tune is about the best you can do. I also own an 88lx and am contemplating taking a EFI b6 from a 323 and swapping the intakes and possibly going electric fuel pump if there is no mech fuel pump provisions on the EFI engine.-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
the 1st gen B6 has the pump lobe on the cam, it's what i run in Scrappy.Originally posted by db2u View PostOk, cool, just was a bit concerned you were going to get in over your head on it. Seriously though, as far as go fast on an 88 carb model... not having a lot of heavy stuff in the back, and getting it in good tune is about the best you can do. I also own an 88lx and am contemplating taking a EFI b6 from a 323 and swapping the intakes and possibly going electric fuel pump if there is no mech fuel pump provisions on the EFI engine.Trees aren't kind to me...
On the B6 cam I have, the pump lobe wasn't polished. Was yours polished or did you run it unpolished?Originally posted by FestYboy View Postthe 1st gen B6 has the pump lobe on the cam, it's what i run in Scrappy.Jack Byrd,
1991 Capri
1988 Festiva LX, 240K
1970 Chev C10
1977 Airstream Argosy MH
i made sure it was smooth... but no need to polish, theres enough oil flying around in there to keep it lubed and the pump doesn't take alot of power to run so the pressure on the arm is rather low.Trees aren't kind to me...
