Slippery slope. If you can refab a floorpan and exhaust you can probably do a rear engined car. Rear turbo rear engined car yes yes yes
b3 intake plumbing
Originally posted by Jblair View PostYou guys are all nuts. . . Turbo, engine swap, cut the rear. Lol. all i want to do right now is change the intake. Baby steps.
Either way, you're gonna have to modify something. There's nothing intake wise you'll find except for the stock intake of the festiva and aspire.
Good luck pal.
-JamesEst. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
That is the crazy attitude here if you're not on the side of the road trying to get home you should be engine swapping. And if you choose not to engine swap its because youre trying to turbo car to beat people who took the easy way out and did the engine swapLast edited by getnpsi; 12-05-2013, 01:22 AM.1993 GL 5 speed
Originally posted by getnpsi View PostThat is the crazy attitude here if you're not on the side of the road trying to get home you should be engine swapping. And if you choose not to engine swap its because youre trying to turbo car to beat people who took the easy way out and did the engine swap
sent from the depths of hell.Ford Festiva 1991 WA Model (5 Door)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
Swap will happen eventually, i really like.mygreat MPG and i wantto.better it. I also have a lot of fun with my 1.3. If i get a ticket i lose my job. I think of.my1.3 as the economicalsafety feature of.the.festiva. I got pulled over doing 58 in a 45, i think the Cop was suprised my car went that fast. Lol. He let me go with a warning.Yellow 91 festiva GL 5speed
Red 88festiva L 4spd
Blue 91festiva L 5spd (bad tranny, sloppy suspension)
I still don't get why RT. If you want a turbo out of the way and close to the ground, for whatever reason, replace the bend in the downpipe with the turbo. No secondary oil system, no LONG intake pipe, and you still get out of messing with the manifold. I know, I know, the fastest Festiva in the world is RT. Is that because it's RT? No.
Just my opinion.Last edited by sketchman; 12-05-2013, 10:53 AM.Any difference that makes no difference is no difference.
Really? I thought it was getting pressurized oil from the feed? Thought it would be fine on its own.Last edited by sketchman; 12-05-2013, 11:11 AM.Any difference that makes no difference is no difference.
Originally posted by sketchman View PostI still don't get why RT. If you want a turbo out of the way and close to the ground, for whatever reason, replace the bend in the downpipe with the turbo. No secondary oil system, no LONG intake pipe, and you still get out of messing with the manifold. I know, I know, the fastest Festiva in the world is RT. Is that because it's RT? No.
Just my opinion.
It does go against all commonplace, known, and proven methods. But it works, and it seems like I had to set some records before people stopped doubting that it actually works.
I know it let's me get away with more boost and timing, than if it were front mounted, and heat soak isn't as much if an issue.-Greg
Redneck Engineer
FOTY - '09
^Well if it works, and it's what you want to do, that's all that matters. I've gone all around idea-wise trying to decide exactly what I want to do with mine, but RT was never something I considered. I'm definitely thinking about the turbo in the bottom of the engine bay, though.Any difference that makes no difference is no difference.
I did it to keep my AC stuff happy, I thought it would work, but didn't think it would work as well as it does. Still surprises me.-Greg
Redneck Engineer
FOTY - '09
I'm guessing here, but a 2nd pump would probably be ldeal.. Perhaps a one way check valve in the return direction.. So that oil won't run back down the pipe.
sent from the depths of hell.Last edited by jawbraeka; 12-06-2013, 05:39 AM.Ford Festiva 1991 WA Model (5 Door)
Avg Economy:
