No it won't hurt. But why bother? All you do us knock out a frost plug and shove it in.
Have you ever knocked out a frost plug before? I always remove them before tanking a block. Drain the rad, get a screwdriver and knock it in a frost plug by tapping it in on one edge. It will rotate so that you can get some pliers on it to yank it out. Kinda like the same way your dentist does to you. Clean the hole with a little fine emery cloth and install the 400W heater. Install the block heater cable while the trace amount of silicone cures. Refill the antifreeze. Good luck.
