[WTS] "I Want To See" pics of the necessary frame notching for a BP /g-series swap. Post 'em if you gottem'
[IWTS] frame notching pics for a g-sereies/BP swap
I don't think frame knotching is necessary, with the trans as close to the frame rail as it can get, it leaves plenty of room on the engine side especially if you run a B3 single belt crank pulley
I've ran a B3 pulley on a NA BP before without any issues, however I'm not sure how good of an idea it would be with boost.... I'd ask Greg (euro) about it since he's obviously had tons of experience with boosted BP's lol
Really, you guys don't have to notch the frame for the BP? Necessary on the BF chassis1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Yep.
Some folks do some folks don't. If you do it makes changing the belt a whole lot easier. If you don't its going to be pretty tight, but it fits as long as you machine off the extra serpentine pulley from the harmonic balancer, or find one that isn't a one piece two step pulley.~Nate
Current cars:
FOTY 2008 winner!
Depending how much power you plan on making 250 or up. i would suggest either a be oil pump or harmonic balacer you will need a large nose crank for bp or b6 depending which motor you usr. As i mentioned before i watch the miata guys theu break more bp/b6s then festiva guys. The weak link of the b series seems to be the oil pump gears exploding due to vibs from the.motor. You can buy a upgraded oil pump or buy a balancer or buy both for extra insurance. If i had to pick just one i woiuld say the boundary oil pump due to i haven't heard of anyone breaking one yet.
You guys are doing something wrong if you're notching the frame for a bp w/g series. I have done it in both a festiva and a BF. With both cable and hydro in the festiva and just hudro in the BF. As for the balancer, mine is the 3 piece b6 with holes drilled through and bolted cause the upper was slipping on the inner, i took off the serpentine ac pulley. Just don't revv over 7k and you'll be fine.
256whp 232wtq on 14psi and 91octane for over 2 years without engine issues.Last edited by fastivaB6TG25MR; 02-24-2014, 01:51 PM.I know its a piece of crap but im still faster...and its 100% legal!!!!!
Haven't done my Bp/G- series trans swap yet, so this is of great interest. If I got this right, the passenger side rail does not need notching/clearanced if using the big nose pulley from the B3 or lopping off the outer BP serpentine pulley.
What about the driver side frame rail? Still need to notch/clearance for the xmsn! mahalo! ....renny'93 Festiva L 5spd.:
Aspire swap: brakes, swaybar, master cyl.
Aloha! ....renny
Notch we did, for the B6T and G25mr combo. We have a BP lying around and measured it, and with the positioning we did for the tranny, a BP would fit where the B6T goes with no further adjustment. Perhaps you could get away without notching at all, but this approach certainly worked, and it keeps the extension lengths of the axles about right. Plus it does make working on the front end of the engine easier when it is in the car. Of course, you are still going to have to clearance the firewall somewhat for the intake on the BP.Originally posted by sketchman View PostYep.
Page 7 of this post has most of the mounting info. Icetiva-3-race-car-build/page7Last edited by Icedawg; 02-24-2014, 04:14 PM.Thricetiva replaced Icetiva as the new ride
i did zero frame mods on my BP/hydro G . The only real cutting i had to do was the lower cross member needed the lip ground off to make room for the shift rods movement. i guess everyones engine ends up in a slightly different spot."Its not fast, but its fast for a festiva."
-----------------------------------------------------------------------------------------------------------Originally posted by fastivaB6TG25MR View Post
I guess I shouldn't get ahead of myself and just wait for the xmsn mounts JT "fastivaB6TG25MR" is making for me. Seems he has it engineered into his mounts where no notching is necessary-I like that! I figure pay the script and save the time & headache, to which I don't have. Just thought the notching/clearance issue was an inherited step when doing any BP swap? take care guys, aloha!'93 Festiva L 5spd.:
Aloha! ....renny
Unless you get a bp turbo intake then you don't have to clearance the firewall. I just used a hammer to move the frame a little bit. It tucks in nicely.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
