I have an aspire and it has egr in the intake manifold. I'm building a new upper manifold and I'll be deleting my egr. Egr is designed to put your inert exhaust gas back into the combustion. This takes up space that would be normally occupied by oxygen, and keeps the combustion temp down during high load low rpm driving. High exhaust temps make more nitrogen emissions. Here's what I was contemplating, water injection on the small scale. And here is my question, the connector that supplies power to the egr solenoid is a constant 12v while the ecm is regulating exhaust gas, right? Could I use this signal and a relay to drive a pump to pump water mist into my manifold? Or is it even worth worrying about the egr? It'd be wonderful getting those water injection cleaning effects during heavy load. Which would have the most use of the water. What's anyone else do?
Sent from my SGH-T989 using Tapatalk
*giddy excitement*
