Hi guys, I used to be on the site quite a bit years ago, I have a 93 with a BP swap that a buddy and I did with a craftsman ratchet set, I come-a-long for an engine hoist and a BFH.  Anyways we did this swap about 6 years ago and now thanks to the Wisconsin winters the car is getting to be pretty worn out, and the motor is getting tired also. So what my question for all of you is, I plan on pulling the motor and and rebuilding it,  getting rid of the car and finding a nicer one to re swap into.  What I am wondering is should I just clean things up and freshen everything and put it back together, or do some other things as long as I'm inside of the motor.  Also I've always thought about boosting it, but I don't know anything about that stuff.  Would there be anything worth doing inside the motor if I did decide to add boost.  I look forward to reading everyone's opinions and comments.  Thank you very much!
What to do with my BP?
It really depends on what your goal is.
For instance, we've recently swapped the head for a 99 Miata head... And that's not a direct swap.
Why? We wanted +9 hp, hopefully we would get it.rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
