any ideas of how to delet a mfs on a 1.3 engine tryin for a cold air intake
look
Mfs? Are you taking about the vaf that the filter box bolts to? If so, the only way to delete it would be a different management system. Something like mega squirt. To add the cone filter, you need an adapter to bolt to the end of the vaf. You can then install the cone filter. You must have the vaf in the system for the motor to run.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
We need clarification of the OP's question from him.'93 Blue 5spd 230K(down for clutch and overall maintanence)
