Sexy.
Quad throttle body manifold eBay uk
I got it milled flat, still need to make a jig on my CNC for drilling the bolt holes.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
The head ports match the gasket size, so they're larger than a stock intake manifold. The other end is 2.2" OD with a ~1.8" or 46mm ID suitable for GSXR1300 throttles, or runners and a plenum could be welded to the stub to make a complete traditional manifold.
The BP port spacing also matches the DCOE standard, so by adding a wooden flange to the pattern it would be possible to cast these with twin DCOE flange instead of an open end. To this you could bolt twin dual side-draft carbs or Jenvey or similar throttles1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Here's the mostly finished manifold, with my drilling jig:
The jig auto-located & centers itself using the ports, and allows me to drill the holes quickly on the drill press without sacrificing any accuracy. Drilling on the mill with the digital readout/coordinate system is super tedious
The lower bolt holes are a little close to the runner radii on the flange
I should be able to run an endmill over this and clear some material away. the runner walls are plenty thick.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Great work as always.-Greg
Redneck Engineer
FOTY - '09
I measured them from a factory manifold & made a blueprint1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
