can you use a 1994 aspire engine in a 90-93 Festiva? gonna build a 40 over aspire engine for my Festiva or get another festiva or aspire for the swap
Aspire engine in a Festiva
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
I just put a 94 aspire engine into a 91 festiva the air intake mounts diff to the aspire head and tps and iac have different connectors and thermostat is tad different 91 festiva has extra sensor. i tryed to swap over everything over from 91 festiva to aspire engine 90% of stuff swaps 91 festiva doesnt have egr were 94 aspire engine does not so i just bypassed it and aspire has 3 vacuum solenoids were 91 festiva only has 1 but they are able to be used on either engine I also had to swap rad lines and divert/remove some vacuum lines
You will need the LARGE nose crank pulleys to put an Aspire engine in anything before late 1992 and 1993. Some late year 1992 Festys had the large nose pulleys, and all 1993 Festys had the large nose pulleys. The Aspire has the ribbed pulleys, and will need to be changed to the large nose "V" pulleys to work on a FestyOriginally posted by old yellow View Postcan you use a 1994 aspire engine in a 90-93 Festiva? gonna build a 40 over aspire engine for my Festiva or get another festiva or aspire for the swap
I am about to install an Aspire engine into my 1992 Festy. I had to locate a set of the V pulleys
The Aspire also has "roller" rockers, which the Festy does not. Should get slightly better MPG with the roller rockers.Last edited by drddan; 07-22-2014, 12:43 PM.Dan
