Weber Jets?
  • Weber Jets?
    What size jets do i need for a 32/36 weber? I cant find a clear answer on which jets i need.
    Owner of a 1989 Maroon Ford Festiva lx 5 speed.
    Depends on your elevation and how you intend to use it. You are near sea level, I believe. For a 1.3 liter I would start with 110 mains in the primary and secondary, then adjust as needed to get the right color plug. Others will no doubt chime in.
      My elevation is about 650 ft and im just using it as my dd.
