What size jets do i need for a 32/36 weber? I cant find a clear answer on which jets i need.
Weber Jets?
Depends on your elevation and how you intend to use it. You are near sea level, I believe. For a 1.3 liter I would start with 110 mains in the primary and secondary, then adjust as needed to get the right color plug. Others will no doubt chime in.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
