What engine to build
    I recommend a B6 with a set of twin carbies.
    Simple install, lots of power and no computer needed.
      computers are good though. especially for boost.
        Ok I'm new to the forum and just bought a 93 festiva 5 speed i use it like a four wheeler I've lifted it and it sits on 28 inch outlaws what is all this i see about a b2 or 3 or whatever
          B3 is the factory engine in a festiva. Its part of the Mazda B series engine line and is paired with an E series manual transmission. (Normally.)
          Any B series engine will fit in these cars without much modification, as well as any transmission that was originally paired with a B series engine. The most common engines in this line are:
          B3- 1.3L SOHC ~63 HP
          B6- 1.6L SOHC ~90 HP
          B6D- 1.6L DOHC ~100HP (?)
          B6T- 1.6L DOHC turbocharged ~120 HP (really just guessed on that one. Haven't read up on the B6T much)
          B8- 1.8L SOHC ~no clue HP
          BP- 1.8L DOHC ~124 HP
          The most common trannies are:
          E series- weak as all hell comes with the B3
          F series- better, works well with most swaps as long as you don't dump the clutch all day
          G series- the best one out there but still has its weak points. Mainly 3rd-5th gear and the diff pins. Weld those in, get a LSD, and order a 4th/ 5th gear plate mod if you really want it to take a beating.
          That's all I can come up with at 1am when I can't sleep.
          Sent from my SCH-I605 using Tapatalk
          1990 White L-Plus 5-speed rust-machine
          Scrapped
          1991 Blue L 5-speed
          daily driver, intermittent project
          1993 rustless wonder
          A shell, awaiting suspension, brakes, and B6T
            This explains a lot about these motors.
            Jerry
            Team Lightning
            Owner of Team Lightning
            93 L Lightning. BP
              Thanks i was looking at maybe doin a swap but for what I'm goin to use it for i think i just put new rings in my stock engine and let er ride. Its just a dirt road toy no tag title or insurance
              Sent from my LG-L38C using Tapatalk 2
