What you guys think? do I need this if Im going to run a turbo? Or would it be a good idea to get? thanks!http://www.ebay.com/itm/Supertech-Du...#ht_3607wt_758
Dual Valve springs!
Not necessary if you're adding a turbo. If you're adding aftermarket cams, balancing the engine, port/valvework & raising the overall RPM limit then yes worth looking into.
Check reviews on these though, that seems cheap? Maybe im out of the loop. Red flag when they say chrome "Silicone" vanadium steel. Silicone goes in boobs, silicon is a metal used in alloys1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Buy them from Jay Meagher at Real Street
Seems like you'd have a broken motor pretty quick if you revved it to 8K on a regular basis. They were never designed to perform that way.Originally posted by bondo View PostThanks rocketman! I kinda wanted to up my rev limit to 8000rpm.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The oil pumps become a weak spot at high power levels and/or RPM levels. The BP can be made to do 8k reliably, but you're better off focusing your powerband down lower1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
I built a 3/4 race overhead valve engine with better pistons and cam, and installed dual valve springs 40 years ago. Got me an extra 2500 rpm but shortened the engine life considerably. The valves were burnt every couple of thousand miles and upgrade sodium-filled versions were way out of my budget. A lot of engineering and upgrade specialized parts are needed in order to gain a couple of thousand rpm and still retain a reliable engine. To me this is where displacement proves to be cheapest option in the long run; a factory 1.8 will stay together for a long time and get you 100+ hp but a 100hp 1.3 B3 will either cost a fortune to build and/or strictly be a short term proposition.
Bondo check out this thread!
DIY Turbo Discussion - I want your spool data! - If some of you remember this thread: https://www.miataturbo.net/forum/showthread.php?t=23570&page=4&highlight=spool we started collecting spool-up rates of various turbo setups and threw them into a chart. I would like to collect new data and try again. So please...
I was thinking after looking over this .. Would they also be ideal for the b6 too?Originally posted by M3NTAL View Post
