96 aspire motor into 91 stiva L
  • 96 aspire motor into 91 stiva L
    Currently working on this project. running into an issue with finding the right crank pulley to run my accessories. The aspire motor has the larger crank with a dual 4 rib crank/accessory pulley. I've already swapped all accessories ( which have the V belt pulleys ). In search of where to go from here. I don't know where to look for a dual v belt pulley which will fit the larger crank.
    Most recent pic
    Just to add I know I'm a noobie to this forums. I am very good friends with "Jake88maro" I'm just looking for some advice here so I can get this project done. We are currently at a stand still, hoping someone knows a little more than us.
      Welcome to the Forum! Recommend you be more specific with your location; might be people nearby who can lend a hand, or just meet up.
      The big-nose cranks came in Festivas built after Jan or Feb 1992, so you would have to source one from a JY in those years. The job is much easier if you don't have PS or A/C, but it sounds like you have one or both.
      Possibly you can use big-nose pulleys from Miatas, Proteges and Capris too, but I'm not sure which years would apply. 1994 for sure, maybe some earlier years.
        I am assuming your 91 engine has the small nose crankshaft and the pulleys from it are too small.
        I believe some late 91's had the larger crank nose.
        This is a common issue. You will need to either find a 92 or 93 JY festiva and get the Alternator and AC pulleys from it or
        add WTB asking someone on the forum to sell them to you. I have pulled and sold a few but there haven't been any Festivas
        in my local PnP for several months.
        Look like TominMo and I were posting at the same time with essentially the same information.
          Thank's guys sorry just made this account a few weeks ago, never updated anything. I'm from North Canton, Ohio. I've got Jake88maro and a good friend of his, Bryant (owns the 900 mile festiva) helping me figure it out.
          To add. Yes I have A/C that actually works. that's why I'm concerned. The aspire motor came with an A/c compressor, but it is trashed, the pulley is completely rusted. Also, yes my 91 came with the smaller crank nose.
          How do i swap the a/c pulley? can either of you lead me in the right direction, also what do you mean by "JY" I'm guessing that is a trim level? Pics or part numbers would be very helpful in this situation. It's starting to get colder and I need to get this car done. I can't drive my G8 during the winter.
          Just so we are clear, I can't just swap crank pulleys? I'll need to swap both a/c and alternator pulleys instead?
            Sorry guys I will try to be as specific as possible here. I don't know a whole lot about these things just yet. I just needed a rust free, reliable, daily driver and Jake helped me out. I was driving a 96 aspire last year but everything stopped working on it. No running lights, no wipers, and someone stole my radio.
              to help him explain whet he has. An Aspire engine in his festiva and wants to put on his Festiva AC stuff that came from a small crank Festiva. All he needs is the Large nosed crank and accessory pulleys from a large nosed Festiva that use the v belt on both. His Festiva AC stuff does not have the ribbed pulley commonly found on cars with Power steering. I am shipping him an accessory pulley that will need spaced out but we are still unsure if that is what he will need.
              If anyone that reads this has an v-belt accessory pulley from an large nosed Festiva this is what he needs.
              -Bryant
                Thank you for the clarification here Bryant. Hopefully your pulley fixes this issue. Fastenal is just up the road so I can find a proper washer to space it out no problem. If not, I'll make one. I just have to be sure it's going to work. I'm not doing it twice, hence the boxes of new parts I've ordered already
                  If your AC works now try to avoid opening the system when you replace the engine.
                  I did it twice when I put new engines in two of my Festivas. It makes it a little more inconvenient but it can be done.
                  You will need the inside pulley that drives the alternator and water pump and the outside pulley for the AC. spacers and the bolts that hold them on.
                  It would be best to get the correct spacers so you belts will be in perfect alignment.
                  I believe the last person that I sold a pulley set to was ajbremer. He put them on an Aspire engine that he installed in his Festiva.
                    I've got no problem refilling the system. It's already empty. I have r12 and r134a at my disposal so that is no issue. Any part numbers? or do you know what model the pulleys were off of? I'll just buy a new one if I have to
                      For the spacer for the pulleys, I used the Aspire "crank spacer".... to explain I took the 1/16 thick, 6-7 inch diameter round pickup wheel that the Aspire uses for the crankshaft pickup, and I turned it down on a lathe at work, to about 3 inches diameter, and used that as the spacer. The pulleys lined up perfect
                      Dan
                        What Bryant sent me should work. I will need a 4 rib pulley for the alternator if that can be changed? If not I may need a 4 rib alternator If someone has a spare
                          Never mind. Looks like I'll be buying a new alternator
                            It's in. I need a lower radiator hose! It seems that the inlet on the block is different for the aspire motor. Should I just get an aspire 1.3L Lower rad hose? Or a universal fit hose?
                              I got a Festiva lower rad hose for mine when I swapped in my 94 aspire engine in to my Festiva... you wanna use all Festiva radiator parts
                              Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
                              Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
                              Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
                              it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
                              Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
                              TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
                              bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
                              '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
                              SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
                              R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
                              R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
                              R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
                              R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
                              R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
