Transmission gears 1-5 are the same in both the festiva and aspire 5-speed transmissions. The final drives is what is different, this is not the same as say....a different 5th gear. The final drive ratio is determined by the amount of teeth on the differential gear and the sun gear. The diff gear in the aspire transmission has 69 teeth and the sun gear has 17 teeth. So 69 divided by 17 makes a 4.05 to 1 ratio. With the festiva transmission, there is a 68 tooth diff gear with an 18 tooth sun gear to get a 3.77 to 1 ratio. So in theory, a festiva transmission placed in a aspire would make for a slower "take off" rate and a higher top end. Conversely an aspire transmission placed in a festiva would make it launch faster but top out sooner. A festiva transmission is better for fuel economy, while an aspire transmission is better for acceleration.
aspire transmission swap to festi
If you don't race, you probably wouldn't notice the difference. Only the people who are putting the pedal to the floor would notice the acceleration difference. Sounds like you drive for fuel economy, so the festiva tranny was a nice upgrade.Originally posted by rickbz28 View PostI picked up an easy 5 MPG when I put the Festy trans in one of my Aspires.I don't really notice any difference in "take off".The Festiva Store
thanks to everyone. well i have a spare now. i took the pan out and the festiva and the thrust bearings on the crank are really worn out, and to me it has exesive endplay, but i dont know that cause i dont know the specs of it if anyone know that the crankshaft end play please let me know i been having a grinding sound on it. wich i thought it was the transmission out of wack wich i tore the old one out and found the differential spider gears and side gears worn out, put it back in the car and it did the same thing so i opted for the aspire trans thinking it would do better on the highway wich i dont mind the faster takeoff, but a little on the top end, so thats how i landed here, and im here to learn so trow some knowlege my way
ya I got one more shot with the Aspire 5 speeds (now with 75-90 royal purple) in my Aspire before I give up and use the better Festiva 5 speeds.....Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
I always thought the Stock Festiva was Faster at everything then the Aspire, but that's just me.... the Aspire is a heavier car as well....Originally posted by nonamekid View PostIf you don't race, you probably wouldn't notice the difference. Only the people who are putting the pedal to the floor would notice the acceleration difference. Sounds like you drive for fuel economy, so the festiva tranny was a nice upgrade.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
