I've successfully welded chipper knives together, take special techniques, and they were so hard on had to cut them with a plasma cutter.
I have a car that to pull transmission, to make it easy, cut cv shafts, I was going to buttweld, then sleeve and wrap ends with weld, plus plug weld.
All it does is roll around parking lot in 1st, top speed of maybe 15mph.
Think it's safe to do? I don't want to spend any more time/money killing the front end to remove engine and transmission. The donor car I killed exhaust, ps lines, fuel, coolant lines, drive shafts with a cut off wheel. 30mins it was out.
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
