Yup. Using the stock manual is suicide though. The auto is a much stronger trans.
My idea with the manuals is if the stock clutch cant hold the power then you probably should run a bigger trans. Basically anything over a B6D or B8 or 100hp.
91GL BP/F3A with boost
