bpt engine swap / 2 questions of many
  • bpt engine swap / 2 questions of many
    is it possible to used the stock automatic tranny ?
    is it possible to put the entire Capri drive train under?
    '89 Isuzu Trooper
    '98 Toyt Previa
    Yes, they are tough if maintained.
    What do you mean? Normally with a BP turbo you will be swapping the G series trans in anyway.
    91GL BP/F3A with boost
      you'd think that if the stock festiva MT will bolt onto a bpt, so should a stock festiva ATX.
        Yup. Using the stock manual is suicide though. The auto is a much stronger trans.
        My idea with the manuals is if the stock clutch cant hold the power then you probably should run a bigger trans. Basically anything over a B6D or B8 or 100hp.
