So I just got a 11psi spring! still got to throw it in and just ordered 550cc injectors! Im really looking forward to hitting 12sec this upcoming 2015 season! Who else is out there trying to hit 12s this race season? gottah figure out how im going to put the power to the ground tho! Hope everybody has a good New Year! Lets kill it!
Turbo Turbo Turbo!
Slicks, and hard launches. Good luck with it, and if there is anything I can do to help, you have my number.
I'm going go for something? Not sure how much is left?Last edited by eurotiva; 12-30-2014, 03:13 AM.-Greg
Redneck Engineer
FOTY - '09
I think after I get my tax return next year, I will be looking at gathering up rear-turbo parts for my B6. I think the only thing I will need to have custom fabricated is a adapter to mount the turbo to the stock muffler flange. Also don't plan to run it at a high PSI at first, just get it to the point where the clutch starts to slip and back it off a bit. Plus that should keep me from needing to get FMU.
Though I am still a bit confused on how you actually adjust turbo pressure, I am new to turbos.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Originally posted by TorqueEffect View PostI think after I get my tax return next year, I will be looking at gathering up rear-turbo parts for my B6. I think the only thing I will need to have custom fabricated is a adapter to mount the turbo to the stock muffler flange. Also don't plan to run it at a high PSI at first, just get it to the point where the clutch starts to slip and back it off a bit. Plus that should keep me from needing to get FMU.
