That was my remedy for the problems we were having with dual gates on a twin turbo. This was the first of many systems I built like this and it ended up being one of those, "duh, why didn't we think of that sooner" designs. Haha.
Anyway, back on topic. The truth is that most modern turbos, even without an ideal wastegate setup, are less of a restriction than the factory catalytic converter and/or muffler. This is common knowledge to anyone who has installed a higher flow exhaust on their modern turbocharged car or truck. Therefore, in this discussion of exhaust pressure being looked at as lost HP, replacing the muffler with a turbo might work well if you live in Florida. The rest of the 49 states aren't so lucky. :p haha.
The trick is to use the turbine to aid the engine with too much valve overlap for proper dynamic compression at lower engine RPM, not to assume the turbine is something that is simply in the way of the exhaust flow. If that were the case airports would be full of large funny looking busses with wings. Fortunately, the turbine is not a flow restriction.
