i found this
im going to the junkyard on wed. so im making a shopping list
 is there anything im missing? aspire: cam shaft and rocker arms. do i need the rocker arm shaft too? is it the same? should i keep the same rockers on the same shaft? is the timing belt gear diffrend? will the dist. still go in the slot in the cam?
also, i still cant find where you get the "HD" springs from... what car are they out of?
 is there anything im missing? aspire: cam shaft and rocker arms. do i need the rocker arm shaft too? is it the same? should i keep the same rockers on the same shaft? is the timing belt gear diffrend? will the dist. still go in the slot in the cam?also, i still cant find where you get the "HD" springs from... what car are they out of?
 anyways, while im at the junk yard is there any other parts that i can grab off of diffrent cars to get even more power out of my b6? i dont care how much it is... im trying to get every last bit of power out of it with out going after market
