Mazda 626
  • Mazda 626
    Hey I have a question would a 2.0L or 2.5L Mazda 626 engine out of a ford probe, be easily swapped into my 94 Festiva?
    Yeah, the hardest part is the transmission mounts.
      Why is that?
        94 Festiva in Oregon? Is it a 93 Festiva or 94 aspire?
        The Festiva Store
          Originally posted by Davis87ford View Post
          Why is that?
          Because you have to make them, you can't buy them.
          The Festiva Store
            That depends on your definition of easy. Nothing directly bolts up, almost nothing directly plugs in and the engines barely fit. It has been done, but I'm not sure if anyone would consider it an easy swap.
              Mazda 626
              Looking back, I think a 2.5 swap is relatively easy
              I guess I'm a little biased since I've done it though lol
              Build thread.....
              Members Builds (questions about repair or how to do something belong in the proper forum)
                ^pfff, "relatively easy". Relative to what? A shogun swap? Lol.
                  Mazda 626
                  Here's how I think of it, I'll use a B6T for comparison
                  B6T/G series swap requires 3 mounts to be made, same with my KL swap
                  Donor harness needs to be spliced in to run the engine, same with my KL swap
                  B6T swap (for most people) has extra plumbing for the intercooler, my KL doesn't need that which makes a little less work
                  KL swap needed a custom rad cross over pipe to plumb the rad.... This could be looked at as balancing out the work with not needing an intercooler
                  The only things I can really think of that's extra work is that the KL needs a diff swap and intermediate shaft mounting bracket, and hydro clutch conversion
                  Otherwise looking back I believe no modifications are necessary to the engine bay to fit the engine and overall there's not too much extra work to go KL vs B6T
                    A lot of people like myself are not handy enough to tear down a tranny for a diff swap though.
                    91GL BP/F3A with boost
                      I think that's the biggest reason why no one else has tried a KL swap
                      The G series trannys are very easy to tear apart though, if you got a junk one kicking around, take it apart and you'll see what I mean
                        I'll tear mine apart when I part out the ol bpt car
                          My apologies I meant to say 93 not 94. I have fabrication skills so I'm not consered about that. Although this is my first tuner style project, so I'm a bit lost on all of this coming from carbonated v8 American muscle stuff.
                            I really just want to know if it's worth going to the bigger liter engine or just trying to find a b6t engine tyrant ect?
                              Cuz in my area where I live I'm only coming across a few escorts and a probe or two.
