Charlie, do you know how much of the head can be shaved before causing issues with compression/valve clearance, etc? The head on my xr2 has some gouges in it and needs to be resurfaced. I just don't know how much it will affect the compression. I believe they will need to take off between 5-7 thousandths, but I don't know for sure.
Ouch. Right on the compression ring.
- Most of the rebuild kit I used was for a 92 Miata since I was using the Miata crank, rods & pistons. Do you think the rear main seal between the 1.5L Crank and the 1.6L crank could be different??? Man I dread pulling it back out just to replace a seal. But with most of my projects it takes me 3 tries to get anything right LOL :banghead:
