DOHC B6 Information
This is a sticky topic.
That is a great topic to bring up.Originally posted by bhearts View PostI'm curious about this, what could provide longer last high power production in a b6 setup. You say with the right intake the b6ze can rev to 7k, so I'm curious, for the same peak power numbers, would it be better turn the boost up and shift at 6k, or turn the boost down a bit a run to 7k
A turbocharged engine can make more usable TQ at a lower RPM than an N/A engine OR it can be used to increase the TQ over a wider range than an N/A engine. It all depends on th design of the system.
There is no generic "correct" answer here, but an answer for every unique set of requirements. Building an engine system should be done with utmost consideration for the application. A Festiva is a very lightweight FWD car, and therefore doesn't benefit from a low end TQ as much as it does from high end TQ when over twice the factory TQ is desired. This is why I bring up shorter stroke benefits on this site. If we were putting one of these engines into a heavier RWD chassis then my suggested combinations would be drastically different. However, this is a Festiva forum and an engine thread which was is focused on swapping these engines into a Festiva.
I strongly believe that a broader and smoother TQ curve will propel a Festiva faster ,on roads and on a road coarse, than a narrower TQ curve (even if the Narrower TQ curve provides more TQ). This is due to the dynamic of the vehicle while being driven. These cars thrive on a momentum style of driving and the more shifting that has to be done, the more often you lose momentum and upset the car. For example, take 2 engines that make the same HP bolted to a G15mr gearbox;
1. 180hp 170ftlbs at 8000rpm with a 100ftlbs available at 3000rpm and a linear curve to 7000rpm where the TQ flattens till 7700 or so.
2 180hp 180ftlbs at 5800rpm with 100ftlbds available at 2500rpm and a liner TQ curve to 5500rpm where it drops off to balivion (with Mike Tyson).
Engine #1 will be boring to drive and feel slow, but it will preserve tires and preserve the driver.
Engine #2 will feel faster to the novice driver, and will be more exciting to drive. This power curve will require more shifting and be harder to use in technical driving situations.
At the end of the day, engine #1 will dominate at 80% of the road coarses or fast road drives with an equally skilled FWD driver in an equally prepared Festiva. This is because the car isn't only being used on a theoritical incline straightaway, like many engine builders seem to design for (linear loaded Dyno). The engine is a dynamic part of a complex system which encounters thousands of variables with each passing lap or daily drive. Big numbers that happen fast don't always provide the desired result. Both cars will accelerate at nearly the same rate to 130mph in a straight line, but when you throw corners into the mix you will see the shortcoming of shorter power curve in a FWD car.
Engine #1 is a turbocharged DOHC B3(theoretical gt2560R @16psi), Engine #2 is a stock B6t with 16psi of boost and Methanol injection.Last edited by Advancedynamix; 12-05-2016, 06:28 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
^lol
You know you want to.Any difference that makes no difference is no difference.
It's a real shame that every single B6 variant all use completely different headgaskets, so no hope for just doing head swaps.
Looks like if I want DOHC power, I actually have to swap in a DOHC engine.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
There are a lot of differences between the single cam and the dual cam b6 engines. The DOHC b6 was specifically designed by Mazda to be a world rally car engine from the beginning. This intent is obvious with the construction and design of it's parts. It is a thoroughbred race engine that was detuned for street use. The single cam engines are economy builds. Mazda doesn't make junk, so even the lowly b3 is a strong little econo pump, but the B6DOHC engine components make the b3 components look like tinker toys.Originally posted by TorqueEffect View PostIt's a real shame that every single B6 variant all use completely different headgaskets, so no hope for just doing head swaps.
The BP is even more robust than it's older and smaller brother, with a monster forged crank and girdled main caps in later variants.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
My SOHC has 4 valves. You guys just swapped the wrong SOHC.
I kinda wonder how much in common the ME has with the D in the same displacement. The ports look very close to D design, and of course the 4 valve CC.
I'd imagine with a healthy cam the MEs would really come alive. Mine hauls as it is. Can't wait to feel it boosted.Last edited by sketchman; 06-05-2015, 04:50 PM.Any difference that makes no difference is no difference.
It should fit better. I don't know for sure about hood clearance, but I do know everything will bolt up, or there are Mazda parts at the salvage yard that will make it bolt up. The engine mount is the only tricky part.Originally posted by stanbu View PostI see that the festiva is the wa model. Do you know whether the DOHC motor will fit the WB 95-97 model.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
It may work, but would require some creativity for sure. Possibly a Kia g series trans to tip the engine? It definitely would require some custom upper radiator support mods, especially if your engine is mounted forward.Originally posted by bhearts View Posthttp://www.ebay.com/itm/1989-1993-MA...CModel%3AMiata
this looks pretty nice. i wonder if one could fit a turbo on top in a festiva like they do in a miata.
Here you can picture the amount of room you'd have for that top mount setup.Last edited by Advancedynamix; 06-27-2015, 08:19 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Mine in the ME will be top mounted. Not log though, tube manifold. It's almost together. Another day and it'll be done. It's gonna be tight. Wouldn't want a wide DOHC head to make it worse.Any difference that makes no difference is no difference.
