Originally posted by errjam
You can use all your festiva engine management equipment, including injectors VAF meter. You will use the Festiva distributor, but you'll need to shave a little off the cam cap that secures the distributor. This is to clamp it tight since the clamp bolt holes won't lign up with the Festiva distributor. You'll run Escort GT plug wires.
