Was reading the ignition timing after full header back exhaust installation post and noticed his fuel pressure set to 42 psi.  Not sure one can do this is a 1992 1.3.  Anyone know how to get that much pressure in a '92?  My regulator comes at 38 psi.  I seem to start running out of gas above 5500 rpm.  Can make it to 6000 and 6200, but can only make it to absolute limit of 6450 on a down hill grade.  Suggestions?
New WIX filter, New 38 psi regulator, Replacement injectors cleaned by machine off the car (equal, smooth flow)
Strong mid range, using MSD and Hi Performance coil.
i218127
i218127
 , we just lost the developmental engine for Carolyn's racing Festiva at Pueblo Motorsports Park this last weekend. testing showed fuel pressure falling off at 7k rpm. A new pump fixed it, but the engine was already done.
