The b3 VAF is practically identical to the b6ze miata vaf. In fact,  Dragonhealer swapped a festiva VAF onto a miata on the dyno and made slightly more hp than the miata vaf. That was probably just a calibration difference, but it proved the point. The Festiva VAF isn't a restriction until somewhere around 140ft.lbs of tq.
In fact, the entire b3 fuel injection system is very similar to the 1.6L Miata system. The biggest difference is the ignition system. However, the festiva has sequential spark ignition, whilst the miata is wasted spark. Sequential spark is better for boost because there is less chance of burning exhaust valves under boost. With that said, in thoery the Festiva engine management system should be better suited to run boost than the miata system. The same tricks that they use to turbo the 1.6 miata will work on a Festiva.
Let's move this type of discussion to the DOHC B6 thread though, to keep things organized.
