Max to who's standards? I go until I cut into water jackets. I'm running daily on 065 removed... And yes, dots disappear around 040.
Just need to run an adjustable cam sprocket.
Edit, adjustable in a single cam, dual might not need it, I had issues of the head going so far down cam walked the belt and I couldn't get precise timing like I wanted.
Sent from my s-off'ed m7 with CM11
Sounds like max to the capability of the machine max.
Max ideal via the manufacturer... I'm thinking that if you require more compression past those limits, it's time to swap pistons...
I'm thinking about taking my b6d head down .035 or so. I'll be running e85 with tons of water and methanol. Interested in off boost economy. Any idea how much until the valve deshrowd?
