Probably. Though you will at the very least need to upgrade the clutch.
New 91 Festiva owner. Want to turbo
Yes, if you do rolling starts and dont do hard 1-2 shifts the stock transmission will be fine with a turboed 1.6Originally posted by BoxerLove View PostIf were not launching the stock 5 speed trans from the 1.3L , will it hold up to the 1.6 and maybe a little boost for awhile? Mostly probably roll races etc. Just having fun with the car.
Some guys have left the stock transmission on a boosted 1.6 and beat on it and it holds up fine for a year or something, other guys manage to break them with a stock 1.3...
It all depends, it will be fine if your easy on it but you will need a stronger clutch of course. There are threads on here about which ones work good.
1.8-1.6 sohc engine mostly bolts in, works really well with a ihi vj14 (b6t) turbo. Buy a good clutch you have ultimate sleeper. Put the turbo in the muffler for best sleeper results. Should be able to do all that for $1,000.1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Sounds great ! And too easy ! So the eng mounts - axles - CV joints - and suspension all match up with the 1.6 and 1.8 transmission? What do you have to look out for? What HP do you get with the turbo - and what does "put the turbo in the muffler" mean ? Would like to try it.Originally posted by Flyin4stroke View Post1.8-1.6 sohc engine mostly bolts in, works really well with a ihi vj14 (b6t) turbo. Buy a good clutch you have ultimate sleeper. Put the turbo in the muffler for best sleeper results. Should be able to do all that for $1,000.
Putting a turbo in the muffler is a rear mount turbo it is under the car usually where the muffler used to be. Sounds amazing and it's cool
Sent from my HUAWEI H892L using Tapatalk88 Ford Festiva LX "Miogi" B8-ME swapped.
93 Ford Festiva L "Haywire" Rat infested trashcan WIP
