I now have 2 1.6L motors. One is from a capri xr2 one is from a GTX. The capri motor is complete and i pulled it from a running car. The GTX motor is not complete. It has the heads the block and all internals. It has has the intake manifold. Along with the GTX motor i bought a used vj11 to pair with my vj14 (hybrid).
The 1st build will be to get the 1.6 in the festiva and get it going with the rocket chip ecu and water meth! 7200rpm redline. The car is a daily driver (i have backups) and autocross.
The second build will come once i have all my parts and have gotten used to the power in the festiva. I am hoping to start the 2nd build towards the end of the year.
SO the only real part of the 2nd build i know is that i want to run the GT2554R turbo. I want to keep the spool time as fast as i can but make as much power as i can get. I will have some extra cash to spend but i dont want to go broke on one single component!!! I will still run the water meth on the 2nd build- might add in some fail safes tho.
What is needed to run the GT2554R to or close to its max? Max budget for this step is around the $3,000 clearly i want to stay as low as i can and still have a fun safe ride but i could spend the coin!
I will have a new exhaust manifold made.
Plan to run a Mega Squirt system
Will have the GTX manifold (could i port it to match the heads and it work) or should i get something built up for me?
