- I'm replacing carb with Weber 32/36 Samurai kit - also about 1300cc - using rocketman's adapter - jetting.
- Blocking off PCV system
- Installing an MSD ignition because I bought one 20 yrs. ago and never used it - will I actually be able to tell a difference - and I thought I'd use the stock coil.
- New plug wires
Need recommendations for the best approach to put together an exhaust system for best performance but a stock noise level. Increase pipe dia. ?? replace cat. converter with small muffler and still use back muffler of some sort ?? any consensus on what to do for the best running engine ??
Recommendation for whether cooler air to the carb has an impact - vs - air cleaner that comes with Weber kit sucking engine compartment air. It's hot in Florida and it looks like the stock snorkel air cleaner might fit on the Weber Samurai air cleaner adapter - to draw in outside air from over by the headlight - maybe it's a little restrictive. Has anybody tested that and felt any results?
Any recommendations for the distributor besides a T between the 2 vacuum lines ? Any spring changes ? Any curve changes work? Stock timing the best for safe running?
I bought this car brand new and now I'm just looking for a smooth, responsive, powerful, semi stock, 1300cc engine - 27 years later.
With Mobile 1 and a new paint job - it'll be the perfect grocery getter.
Will I be able to hit 102 mph ?
Thanks
- New plug wires
Thanks
