Would I be able to swap a aspire 1.3l into my 93 festiva with no problem
Need some help
Short answer: yes. Only use the short block with head, the rest must be swapped from the festy.Trees aren't kind to me...
Yes, you just need to swap intake and exhaust manifolds, and the Disty. not sure if there's anything esle. and it does matter I'm thinking if its out of a 96-97 Aspire which are OBD2. 94-95 are OBD1 just like a Festiva.
Festyboy was a little fasterLast edited by Team Lightning; 06-09-2016, 10:31 PM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Yes, but all aspire dizzys are not compatible with Festivas.
You'll also want to swap the crank and water pump pulleys as the Festiva uses a V belt where the aspire uses a 4 rib serp beltTrees aren't kind to me...
you don't need to switch exhaust mani if you don't want to. I've Been running with aspire mani and downpipe for years nowLast edited by joeboomer999; 06-10-2016, 12:48 AM.
